So I’m running into the issue where the numbers are no longer matching up between what the Power Meter says is going on vs, the values I see in my “Bubbles”
For example this is what my PowerMeter has been showing:
As you can see when hovering over the timeline the power meter shows me about 236 W is being used, but the value in the top right (not sure what to call it) shows 604 W !?
Also when I go look at my “Now” screen it shows me 604 W there too and all my bubbles add up to the amount now too (yay?)
But still, the “PowerMeter” screen continues to show a lot lower usage!? And I’m actually thinking that the PowerMeter value is the correct value as well as I should not be using 604 W at this time so I’m thinking a lot of power is getting double counted somewhere in the bubbles. Basically my 3 Smart Plugs (Office Equipment, Entertainment Center and Smart Home Equipment) should count for almost all my “Always On” power as the only other things that are currently “always on” are things like my microwave clock, 1 clock radio and my Xbox One (in standby/off mode) and that’s about it. Everything else (besides the equipment on the 100S plugs) is not “on” as there are smart plugs on everything else and they are turned off.
