How was your issue detected?:
I’m new to Sense, about 10 days in now. I already have some devices identified which is fun. Interesting pattern has already emerged with respect to power quality, though - voltage dips. Labs is reporting over 1000x dips and I’m curious if anyone has any thoughts. I don’t notice any typical symptoms like lights flickering or devices rebooting/resetting. The pattern seems to be that voltage peaks around the low end of normal range in the overnight hours but is nearly consistently under (sometimes way under) the normal range during daylight hours.
I don’t think I’d ever have thought or suspected a power quality issue without the Sense. Labs isn’t reporting any floating neutrals, either.
Very interested in thoughts or advice! Hoping to learn something.
