Is it advisable to place SENSE in a RFI Shield to avoid the frequent need for reset?
@zekewilson, the Sense monitor is built and designed to live inside a breaker panel with the associated RFI. The WiFi antenna should extend outside the panel to avoid signal loss through the metal box.
More on the monitor here, though mostly from a SW perspective.
Here’s a view into an earlier version of the hardware. I think the current monitor uses an STM embedded processor, instead of TI.
