In that case I’d warn you not to run your pump dry. That’s a great recipe for a dead pool pump and explains the pattern of behavior. If you resolve the priming issue sense should see your pool pump like any standard single speed pump.
I have the same issue with my variable speed pool pump. It’s regularly turns on and off the same time everyday but sense still cannot find it, which is frustrating because it’s one of our largest engery consumers.
Sense detected my variable pool pump but names it AC 3. it also only detects it if it turns on via the timer. if I interrupt it or turn it on or off any other time, it will not detect or show correct on off status.
