Sense meter is giving very different data than Enphase. It shows usage WAY above production when the solar panels are producing and negative usage when the sun is down. With always on devices like the fridge and freezer, it is not possible to have negative usage. Sense had found the water heater and AC/heat pump, but after Support made changes last week, it does not find anything except the icemaker. Please help me make sense of the difference between Enphase and Sense. In this screenshot the batteries are fully charged.
Your Total Usage correlates way too closely with your Solar Production - that’s typically an indicator of a configuration issue. Talk to support@sense.com, even if you have already been in dialog with them already. They are the ones who can correct.
