Unknown mystery device
Ive got an unknown device that goes on for 10 seconds, then off every hour, usually to the minute. It draws 38-40 watts. I thought it might be an air purifier sampling the air but ruled that out. Occasionally, there may be a several hour period of no activity, but that is the exception.
I forget the wattage, but I ended up identifying similar behavior as an icemaker. It was regular about dumping the ice, and would occasionally go quiet if we didn’t use any ice for a period of time.
One other resource in your search - the Community Device Library.
Here’s a view of some detected devices in the 0-50W category:
https://community.sense.com/tags/c/device-detection/device-library/25/1w-50w
Since you’re nearing the edge of the range, a view of the 51-100W as well:
https://community.sense.com/tags/c/device-detection/device-library/25/51w-100w
