Want to connect to new WiFi beacon
Hi all, new user installed only 5 days and have 3 identified, personally confirmed devices.
I just installed a new eero mesh WiFi beacon much closer to Sense system for better home coverage. If I just cycle power on the Sense breaker for 20-30 sec, will Sense reboot and connect by itself or do I have to walk back thru connection sequence? Since the beacon is part of a mesh system, it has the same credentials as the rest of the system as it is not a separate beacon with unique signal. Are my thoughts correct that with power cycle, it will re-up to WiFi on its own?
Thanks,
norenlaw
afaik, it should reconnect if the SSID is the same, and password is the same as the old network. If not, you’ll have to go through the reconnect steps.
