The second device that Sense detected was a pump. It looked like it was the well pump as it turned on for a minute at a time when the water was running. Seemed pretty straightforward but over the next few days I noticed it was also “turning on” when our smaller heat pump also turned on. It doesn’t happen 100% of the time but it does happen a lot.
Is this something that the system will eventually disentangle on its own? To my untrained eye the devices don’t look much at all alike when they start. The heat pump has a higher startup current but a lower overall watts used. The well pump startup peak is much lower compared to its run usage.
Should I delete the pump and let it re-identify or just let it sit for a while and see if it separates the two? My concern is it won’t really capture the heat pump usage in its current state.
