At what point do you just give up on Device Detection?
Can understand your pain, but you suggest a couple things that are a bit off-base.
First, I think you might have missed it… The return policy is 120 days now.
Second, you are clearly in the weeds on the technology part if you think it would be easy to have you “mark” devices via patterns in the Power Meter, unless you are talking about manually marking each and every usage. But maybe that’s what you want ? I can see value in being able to measure the on portion of waveforms in the power meter more effectively.
