cool, its like the rokus… I have (2) Streaming Stick and (2) Stream Stick+, all powered by TV USB port… they are 3-5W depending on what they are doing… I was actually surprised something so small and complicated was so energy efficient… heck, they even feel a lot hotter than the wattage they use… lol…
Maybe an older wireless router or older stereo receiver or something along those lines? That could use that kind of crazy wattage before energy star and could be on 24/7.
Something to look at, assuming it’s hard wired. Sensors do sometimes go bad. It is also much more likely than a pump or something that might burn itself out if it was malfuntioning. At least it’s an easy thing to check, not like crawling around in a crawlspace or kneewall ugh!
How about a doorbell transformer. They run 24/7. Mine is a 40 va. It runs two bells, a lighted address and a Ring doorbell. It is 24 volt on secondary side, but who knows.
The mistake we all make (IMHO) looking at these signatures is beginning by assuming that because the Sense algorithm has decided it’s a “device” doesn’t mean necessarily that that signature is coming only from separate device and represents the entire device usage. It could be a component of a more complex and larger wattage device.
For the most part it looks like a fridge/freezer signature as @samwooly1 suggested.
Have you tried killing power to your fridges/freezers briefly while watching the device power meter?
Also, it seems to be similar to the general usage of my fridge (38W with spikes at 150W).
My fridge I think is misbehaving and running longer than it should be … I just posted a thread about it here.
A lighted doorbell usually draws 2-3 watts (each button), when not ringing the bell. I’ve not measured what it draws when ringing and that would be highly dependent on what your ringer is. Hopefully it doesn’t ring for long. Each button therefore draws about 27KWH/year, or $4.86. Frankly, that doesn’t worry me and I don’t care if Sense ever finds my three lighted buttons.
See the kind of amusing article at https://www.dailykos.com/stories/2008/9/8/591550/-, where he points out that such a small draw adds up to 2.6 BILLION KWH for the whole USA and generates 1.8 MILLION tons of CO2.
And, no, I haven’t checked his arithmetic. Personally I’m NOT turning off my three doorbells anyway.
I don’t think the Ring doorbell alone would draw 35 watts. If you have it connected to the wires from your old doorbell. There may be other things hooked up also like an address light as in my case.
