I installed my Sense 10 days ago. Apparently I put the current sensors on the “wrong” lines in my breaker panel, because while my refrigerator is in fact on L1 it shows in Sense on L2. Can I swap the current sensors to the other feed lines, or is there a way to tell the app that the current sensors need swapped, or do I just need to remember that L1 = Sense(L2) and L2 = Sense(L1)?
So far Sense has identified the oven (240V, shouldn’t matter if I switch the sensors), the 2 furnaces (one on each line) and Heat2 (which is the inducer blower part of furnace1).
