Be careful what you wish for with every component being detected in your fridge. I’ll use my fridge compressor, fridge defroster and fridge lights for this example. Those three have been detected on mine. But if they were to end up merged together then every time someone opened the door, it would say “fridge is on”. Oh, also the ice water dispenser is detected so it would be the same. Tones of fridge on and off notifications when it wasn’t the fridge actually running th compressor or fan for cooling purposes. I want these components detected separately for this reason so they are not merged together.
I’m not sure what having a HS110 would do in this respect. Does anything that happens with the fridge trigger a notification or not? @kevin1 would know.
