Log/chart for Voltage and watts per phase
With sense already seeing the voltage and wattage for each phase, can that be an option to graph as well on the screen or on a seperate screen? I ask this because I noticed the loads are not evened out on our panen and to see this could help better distribute them. This is also useful because it appears like we have some minor voltage drops and I would like to correlate these with evens in the house. For example: With LED lights on a dimmer and they are set low, I notice they will blink off occasionally, which leads me to believe the input voltage has dropped and the circuitry can not make use of it when the voltage is below a certain amount.
7 posts were merged into an existing topic: Track Use by Phase
