My sense is confused
It has been a week and my sense has picked up a few things. Nailed my pump, my cooktop and oven. However, now that I am using my Bosch dryer, it is saying my cooktop is on Hmmmmm not a biggie just thought I’d share. If I turn on a cooktop burner , the “other” bubble gets bigger, then the burner bubble from the dryer disappears and then the bubble re-appears as the cook top burner cycles on and off. Like I said, no biggie. Just odd behavior :slight_smile:
Hi @Mars - glad to hear Sense found a few big-ticket items early on.
It sounds like the heating elements in your dryer look similar to the heating elements on your stove.
The next time this issue presents itself, I would recommend:
  1. Clicking on the device
  2. Navigate to Device Settings via the gear icon in the top right
  3. Click on “Manage”
  4. Click “Report a Problem > Device Not On”
This logs the issue for us to improve Device detection for all users moving forward.
If you don’t have Solar, check out Dedicated Circuit Monitoring with a pair of flex sensors. You can monitor up to two 120V or 240V devices that will show up immediately after set-up in the app. Included more information below:
