Negative power with big drop in measured solar production
Once you get Sense solar, you will see two things in all the displays.
  1. Total Consumption of your house (net usage plus Solar Production)
  2. Solar Production - power coming from your solar back-feed.
With data export you can calculate hourly net power. The one thing you won’t be able to pull out is exactly how much accumulated real-time energy you took in from the grid and exactly how much power you have exported to the grid. You’ll only get the hourly nets.
OOooo I use splunk daily… Someone write a prebuilt splunk app for sense? Or do i have to do it myself?
Home assistant has a sense plugin. I forward that to splunk using the HEC.
I ran across this thread having experienced the same problem over the past 3 weeks. It’s becoming more frequent, now occurring every 2-3 days. Sometimes it will resolve on it’s own within 6 to 24 hours, or I can fix it by cycling the sense monitor power. When in the problem state solar output is incorrect, and one of the mains reads negative power.
