Hi - is anyone interested in identifying this relatively new device? It runs for about 15 seconds every minute at unpredictable times of day. Maximum power about 167 watts.
If it runs consistently every minute, it should be fairly ‘easy’ to identify. I would disconnect the usual culprits (fridge/freezer/…), one at a time, and watch until the peaks disappear. 167 W is fairly ‘high’ and thus easy to identify.
If not, try shutting off the breakers in your basement, one at a time, until you identify which circuit the device is on. In doing so, make sure the circuit on which Sense and your modem/router are always on.
Our Kuerig gives a similar signature with slightly higher peaks of about 200w when in standby.
