Sure, but sense is pretty accurate once it detects something or a HS110 has been spliced into the line.
If there’s no plug because the appliance is 240v and sense will not detect then we’re forced to splice a HS110 into the line itself like I did. Is that an option for you?
I bought an amp-meter with a loop so I could see the amperage being drawn and decide whether it was feasible to have an HS110 report the load. You’ll have to decide for urself if ur comfortable with the config…
Good luck!
