One dedicated circuit not reading wattage, the other is fine
Installed dedicated circuits on garage door opener and sump pump. Both recognized their respective loads during set up, but the garage door opener has shown nothing since. Opener device was recognized on mains, and I merged it (maybe stupidly) with the dedicated circuit. No device action since and still no wattage on dedicated circuit. Opener wattage continues to show up on mains as Other, about a 400W jump when active. Sump pump dedicated circuit working fine. I opened the panel and reinstalled the sensor on its wire and ensured it is closed and facing same direction as other dedicated sensor. Any ideas on next steps?
Edit: went through dedicated circuit set up again and everything working now.
Experiencing a similar issue.
Resetting only temporarily fixes the problem for me.
Experiencing the same issue after moving to a new home. Just did a factory reset and completed the installation. I’ll try to re-complete the dedicated circuit setup as already suggested.
All fixed now. Both dedicated circuits reading properly. Re-completed the set up. (and corrected an issue with the voltage wire connection).
Hi,
Thanks for letting us know. Sorry for the slowish response here. If you need any help you can send me a private message and I look into this issue for you.
Thanks!
