I just got a Philips Hue Bridge & 4 bulbs. Bridge is fully setup & connected to Homekit. Works both at home and remote. While at home and connected to Wi-Fi Sense does not see it. Both have IP’s on the same subnet. When I try to add it says “Not found”. What am I doing wrong?
You’re doing all the right things. Usually the start of the Integration requires the user to tap the button on top of the Hue hub. What version of the hub are you using ? I think I have a rev 2.
It’s new so I would guess rev 2. Good call on the button, I didn’t think of that. I’ll try that when i get home.
The button didn’t help. I’m missing something.
