I’m seeing a vast discrepancy between what sense reports and what I am being charged for by my utility. For example, in the month of December, my bill was $639, for 2623 kWh.
Sense shows 347. I don’t know how to see the kWh sense had, but the electricity charge of .125/kWh configured in sense is correct.
Thanks. I had to call National Grid, but I now understand what’s going on. I am being charged separately for supply and delivery per kwh. I was just looking at the delivery charges. If I add the supply and delivery charges, I am being billed 24 cents per kWh. Does that seem reasonable - is that similar to what you pay? Seems like a lot!
Depends where you live. My EV2-A rate ranges from 17c (off-peak) to 48c (peak) per kWh in CA. I installed solar in 2013 via a prepaid power purchase agreement. I get that power for 10c per kWh, plus they pay me back if the panels don’t produce the full amount I paid for…
Check out this thread from a while back. There are a couple examples of bills. But short version, yes having supply and delivery as two seperate things is common which makes coming up with your kWh rate slightly more complicated . You will probably have to do some math.
