I have a couple of higher draw appliances that aren’t regisgering correctly. Sense grossly under reports the Watts on the a/c compressor by around 1000w (not counting the furnace blower (gas furnace 120v) which it did separately discover, though never shows as operating while the a/c turns on, only during heat cycles.
I
also have an oddly reported water heater that shows a wattage use than the current total wattage use.Should I delete discovered devices and wait for them to be rediscovered?
Thanks!
