Solar not Showing
Set up my Sense today and my solar is not showing up. The CTs are on in the same direction could it be that my solar is ahead of the main and the production does not go through the main CTs?
I can’t answer your question @sparky427jrej
But I do want to welcome you to the community.
Here is a link to a page that may help and has diagrams
if you had sense prior you have to enable it. There is an enable solar section under. Settings-> my home -> sense monitor -> solar. It requires you to turn off/on the inverter. After that it should show.
