Make: Sony
Model: XBR77A9G
How identified: Smart plug
Additional Comments:
Thanks to little extra disorder in our family room, I was allowed to put a non-aesthetic HS110 on our TV. Due to physical clearances with the wall mount and recessed power, I can’t put the TV on permanent HS110, so it gets the Traveller this week.
Power Specs: *
POWER CONSUMPTION (IN OPERATION) - 653 W
POWER CONSUMPTION (IN STANDBY) - 0.5 W
Detailed View:
The Device Power Meter highlights power usage in standby and on mode with 4 different video streams, all coming from a 4K AppleTV.
The first segment is standby mode power usage after powering up the HS110 - 26W. I gotta figure out why it’s at 26W vs 0.5W
The second segment is the static AppleTV menu - Even though the display is static power, usage elevates to about 400W, then drifts down to around 350W. Oddly the power seemed to plunge every time I moved the cursor across the screen.
Next a couple of Karaoke sessions with the The Script and Rihanna. I should be clear that the audio is routed through the stereo and external speakers so the power utilization is primarily flowing to video processing and the screen. What’s fascinating is that a slowly moving screen uses less power than a static one, and Rihanna uses far more power than The Script ![]()
The final segment is a fast moving clip from the 4K version of Ford vs. Ferrari. Oddly, power drops again when displaying 4K details at dizzying speed. Go figure - not as expected.
Waveform Source. Device Power Meter (Using HS110)
Update: Another long session with the TV on and connected (mostly) to the AppleTV 4K. The repeating pattern is a set of screen saver videos.
And an even longer term view. 5 days of the TV on my Traveller
