When you add up the watts on the device list it is always more then what it shows for the total on the Now screen. Two devices are smart plugs, fridge because it’s a linear inverter compressor and network rack (measures my network related items, router , poe devices, nas, modem) Is the app not adding stuff up right with the smart plugs?
Good observation! The total of your listed devices is more than the displayed usage. This is likely because your network rack has a large Always On component. If you click into Always On, you should be able to see what portion of the network rack is part of that value. If you then subtract that portion, your totals should add up as you expect. Your linear inverter fridge may also have an Always On component that you need to subtract out.
