Two pairs of Consuption CT on the same grid conductor
I have a Enphase solar array. It was installed in 2010 and I currently have a legacy Envoy gateway. I am in the process of upgrading to the newer Envoy-S Gateway. The Envoy-S has two CT’s that clamp around the Grid power lines for measuring consumption. There is not a lot of room in the panel. So any idea on how much distance needs to be between the Sense CT and the Enphase CT so that there is not any interference between the pairs of CT’s?
Anybody install both Envoy and Sense CT’s if so what issues did you have?
Thanks
they can be snug next to each other without any problems.
