A widget or widgets to display info like power generated and power consumed on the home screen would be excellent.
Thanks for the suggestion, @michael1! Just to make sure I understand, when you say home screen, you mean the home screen of the phone, not the app, right?
Yes, That is exactly what i mean. I was previously using the enphase solar
monitoring app which provides that kind of home screen widget and it was
nice to have the info at a glance rather than needing to dig into the app
itself.
I’d like to bump this, would definitely like to see an Android widget. It could be a rather simple 1x4 that includes something like [ Sense Logo | Current Usage | Current $/Hr | Month kWh | Bill $$$ ]. I’m sure others would like to see other variants - maybe a one-liner 24H graph, or the variation above but with solar production, or instead of $ show number of devices turned on and always on / other markers. 1x1 widgets could be used to show state of individual devices - devices turned on and current usage.
I purchased Sense to make to bring attention to my power usage. I had been hoping to be able to do things like include 24H or 30-day graphs on my actiontiles wall-mount displays (I know about the third-party ST integration marked as beta), but it seems access to data is pretty much limited to opening the app… Which doesn’t exactly remind me to check / use it unless I think about it which defeats the point.
Well at least I’ve managed to add a graph of my last 24H of power usage. Disregard the bland colors, it’s meant to blend in with my ActionTiles wall tablets.
???? Hmm
What ??? Hmm
trying to see how you did that
I’m using the SmartThings Sense handler at GitHub - brbeaird/SmartThings_SenseMonitor: Connects SmartThings with Sense to pull data into SmartThings
I then export that data as it comes in to Google Sheets using SmartThings/ReadMe.md at master · krlaframboise/SmartThings · GitHub
That data is then filtered so it only shows the last 24H of data, then it has a chart built which is published as an image URL. I can then use that image in ActionTiles and/or using an Android app that allows placing image URLs that refresh every X minutes on my phone.
This would be quite useful. Just a display of the number of watts used in the App (like e.g. the Verizon App shows you how much data you still have for the month) would be great. A graph like the one shown by @cody above would be even better.
Bumping this one up, Id like this feature,
Wondering on the status of that, it would be useful
Yes a widget would be awesome. Homescreen smartphone widget(Android). Or even a live wallpaper/screensaver. I set up a rarely used old tablet on my side table in the living room. to watch as things go on and off see the patterns etc. I leave the app open. Unfortunately the tablet screen times out and have to occasionally reopen it.
Yes, please make this widget!!
Bump. Why hasn’t this happened?
My post needs approval, 6 years and nothing?
Only 15 Likes over 6 years. That puts this Wishlist item pretty low on the the user interest list, based on what I can see. To put it in perspective, many Wishlist items have well over 100 likes, some over 200…
Less lines of code vs weeks the post has been up
