Always show wattage on mobile bubbles
I noticed that the bubbles on an IOS device will show the wattage after you touch the bubble (screen). The bubble size will increase and show you the wattage for 5 seconds. The website bubbles show the wattage inside the bubble and it stays in the bubble. If the wattage change it will change on the website automatic I really like the fact that I can see the wattage inside the bubble without touching the screen. Is there a setting in IOS that I missed?
There is currently no way to persistently show the wattage on mobile. I re-titled this thread to better reflect the ask.
I can imagine the rationale was that the UI is pretty tight with the bubbles (on a phone screen) and squeezing that additional info there pushes things toward incomprehensibility. You need to work with the lowest common denominator in that regard. That said, there would be a few methods:
  • Automatically abbreviate the device names (or allow for a user abbreviation) and then squeeze the watts in the bubble.
  • Allow the timeline to be collapsed in bubble view to give more real estate. That could be related to landscape/portrait views or add to the bubbles/meter modes and have another view.
  • Overlay the device name on the persistent wattage display rather than stack them within the bubble (this would maybe be modal so you can revert to a simpler name-only view).
Many options, but I think Sense has struck a good balance here and kept things informative yet simple.
