Antenna Placement
Hi a newbie here so some of my questions may well be a Dhu! questions
One to start:
My breaker panel is in wall and after punching out what I thought was a good place for the antenna I found the antenna is close to the 240v dryer plug (maybe a few inches)
I did have an issue on startup that generated a pop up on the "Now " Screen saying there was an issue but since then it seems to be working fine.
Tech did reach out and said I have an average signal strength of 236/Kbs
but if I move the antenna further from that 240 source can I expect a stronger signal?
Thanks
Steve
Hi @Brightonuk, if you are worried that your Sense monitor is not running well or dropping off, you should move it somewhere a little better. If your monitor appears to be okay though and regularly connected, you should be fine.
