Make: BMW
Model: 2014 i3 ReX
How identified: Smart plug (Wemo insight)
Additional Comments: The first charge cycle is the normal charge cycle, the second small charge cycle is what i believe is done after the batteries have balanced out and this is to top off the batteries and the third charge cycle is happening when my car is running its auto climate control for the set departure time.
Input Power Specs: 115V 12A, 60Hz
Detailed View: First view is of a 12 hour period showing three different charge cycles:
Next view shows only the first complete charge cycle.
This view shows the beginning of the ramp down of the first charge cycle.
This view shows the complete ramp down of the first charge cycle.
This View is a fully zoomed in view of the smallest complete charge cycle.
Next view shows the beginning portion of the third charge cycle.
This view shows the characteristic dip at approximately 10 minutes into the charge cycle.
This view shows the detailed view of the ramping down of the third charge cycle.
This view shows the middle of the third charge cycle ramp down.
This view shows the end of the third charge cycles ramp down.
Waveform Source: Device Power Meter
