Changing the breaker Sense is attached to?
Good Afternoon All,
I will be rearranging some of the breakers in my box over the next few days and wanted to put Sense on a separate breaker. Will changing the breaker Sense is attached to effect the data gathered and device detection?
Thanks!
–Harry
Moving the power shouldn’t have any effect, however, if you move the CT’s there may be some minor effect, although negligible.
I would be very careful to make sure that the wires attach to the same busbars they are currently attached to otherwise you may really screw up detection.
[quote=“Howard, post:3, topic:776, full:true”]
I would be very careful to make sure that the wires attach to the same busbars they are currently attached to otherwise you may really screw up detection.[/quote]
I forgot about this. Absolutely correct! The black and red power wires must each be connected to the same phase as they were previously on.
Just as Howard & Ira said, make sure that the wires are reconnected to the same phases of the panel to avoid any issues with device detection.
