This is not terribly dissimilar from the other topic on integration with home automation; I’m just breaking out Control4 into its own topic.
There are two parts to Control4 integration I’d really like to see. One is being able to have Sense pull monitoring data from the Control4 switches, similarly to how it already does for Wemo plugs. The other is to be able to natively use Sense device notifications in Control4 programming, rather than relying on IFTTT.
There were a lot of good ideas in the other home automation thread that I think also apply here as well.
+1
Sense has not detected any of my lighting, I am guessing it is because of the Control4 dimmers that fade on and off. The dimmers already have load monitoring data. And as pointed out you already pull data from others like Wemo and TP-Link Kasa.
Just getting my sense up and running, and I’m aware all my lights will be absent. Would be nice to put in the servers and stuff. C4 and sense should be able to track av pretty well.
