Does Sense detect devices based on small signature signals (pump/heat turned on once) or does it detect an entire run of a device(pump/heat turned on 2-3 times during x duration)? Started up the dishwasher this morning but I changed it to a 1 hour run time since the dishes just needed a quick rinse/steam. Curious if I am going to get Pump 1 and Heat 1 for standard wash and Pump 2 and Heat 2 for a 1-hour wash.
There are a lot of devices that would fit into this category, a few I can think of that you may use different modes on.
Coffee Maker - Normal vs Strong
Hot Tub - Clean Mode vs Use
Washer - Different Clean Modes
Dishwasher - 1 Hour vs Standard
High Wattage Lights - Full Brightness vs Dimmed
Cheers,
Brian
