Does the HS110 outlet need to be in the same panel as Sense?
Missed your goal here in the original post!
Shout-out to Sense Graphics Department: Would love to see your cute green wood splitter solve!
Not having chopped wood in a while I have no idea how much juice an electric wood splitter uses. What is the spec on it btw?
In theory you could use a set of Solar CTs (if you’re not using them already) and loop those on the wood splitter circuit … assuming it’s dedicated.
I’m clocking my Hot Water Heater & AC in that way as discussed here.
