How was your issue detected?: The EV / Chargepoint integration no longer works in sense labs.
Did you noticed any other signs of this issue around your home?: I try to click on it but it gives a code error. Since it seems to be discontinued, I’d like to make sure all I have to do is disconnect Sense from within my Chargepoint connections. I know there used to be a disconnect from within Sense Labs but that code no longer is working.
Hi @sjudd06, I will look into this and let you know when I get more information.
Unfortunately, I do not have a timeline for when I can confirm this is resolved or have some more answers, but if you want a follow-up, just @JamesDrewAtSense and ask for an update, and I’ll do the best I can to provide one.
