I have reviewed the following post about the Signal Check process: What is 'signal check'?
I would like to know and ensure other users understand what else to expect during this process.
For example, at the moment my system has been installed for less than 24 hours. When I view the Monitor under Settings>My Home>Monitor, I see that the Signal check is 0% Complete. Should I expect this to be 0% until it actually completes? Is there an expectation of there being a progress bar which advances?
Another example: I go to view the current power meter during this period when the Signal Check is supposed to be running and I see little events occurring on the timeline indicating usage, but these are not actually being graphed that I can tell… I still see a flat line across the bottom with pinch to zoom for viewing higher data fidelity not having an impact. At the same time, the total watts in the upper right corner of the meter screen always shows “0w”.
Is this expected behavior during the Signal check process? Or indicative of a problem? It would be great to have an article out here which helps people starting out to know what to expect. Screenshot below:
