Reaching out for some help here; tried everything I could think of and even sent a ticket to Sense (un-answered). I have a small 800sf house with everything possible run by propane, a diesel 7kw generator. I plan on using the generator off site in my construction business, so I have it wired with a generator inlet on the house and an interlock forcing the mains off before the generator is allowed to see the buss.
I ordered a set of flex solar cables and put the transformer clamps on the incoming lines from the inlet box. Even with full load, the Sense will not “see” the generator when attempting to set up. It says load is too low; even though I loaded the circuit until it tripped the generator’s on-board 30a breaker. The Sense does “see” the flex cable.
I’m beginning to think either the flex cables are defective, or I am being a spectacular dumbass and not seeing something obvious. Can anyone help?
