Is it possible to work with SENSE Technical Support on goings on, in the monitoring/logging of my account at a given time?
In this case it would be between 12:00 and 12:30PM Pacific.
In my ‘other group’, I had around 3K Watts, and at that time my pool pump was running (which hasn’t been detected still).
It’s a ‘smart pump’ and it’s able to display the RPM and WATTS and so far it has been in-line with what SENSE reports when I turn it on/off as within +/- 10-20 watts.
I’ve been posting some concerns about mis-detection and mis-reporting/logging of wattage and/or device activity and wondered if SENSE is splitting wattage detection/usage.
In checking what the PUMP says it’s using, its around 2400watts
I turn the pump off, and my SENSE Other group, drops to 1300watts… not closer to 600/700 as expected.
