Kevin1 replied to a post Sept 2022 by synbios88 that he had seen community forum member(s) wire 2 sets of flex sensors in parallel to monitor a second solar feed where the breakers were too far apart to clamp one set of sensors around both wires of the same legs of the separate solar feeds. I am wondering if anyone has also done this with primary sensors to monitor a second subpanel (within the CT spec limits of 250V and 200A)… I would also be interested in reading the OP of the member who used parallel CTs to monitor separate solar feeds. I would like to do both, use 4 sets of sensors in 2 parallel circuits to monitor a second solar feed to a second subpanel. The cnx are not very far from my original installation… Theoretically it should work…
