Just when I thought Sense was improving its accuracy with the voltage fix THIS happens and has me questioning what is going on. I have my downstairs Fridge plugged into a Kill-A-Watt unit and that is how I originally found the voltage problem with Sense - now it reads the same voltage as Sense, so that is good. Sense was just showing the Fridge was on so I went to check if they matched in wattage. Sense said it was pulling 213 watts, unfortunately the watt meter shows it pulling 104 watts - THAT IS A HUGE DIFFERENCE !!! The meter shows it pulling 0.89 amps at 119.5 volts with a power factor of 0.97. Yes I flagged it for support to look at it.
Related topics
| Topic | Replies | Views | Activity | |
| Sense is not picking up voltage or watts but is connected | 15 | 758 | March 13, 2023 | |
| User-Calibrated Voltage | 6 | 915 | April 20, 2017 | |
| Voltage discrepancy fix just deployed - let us know if you still see issues | 43 | 6321 | February 13, 2019 | |
| Sense show 0 Watt & 0 Volt reading | 5 | 713 | February 6, 2021 | |
| Power Reading Dropped to Zero Watts | 8 | 2219 | February 8, 2019 |
