Sense is a great product and is one of my favorite devices that I own but it’s not without it’s flaws. I have owned two seperate Sense meters now and have been using Sense for four years. Over the past four years I have learned a lot about my two different houses and even tracked down several devices that were not working correctly because of Sense. One of the biggest flaws that I believe Sense has is the lack of being able to save the meter data when doing a factory reset on the Sense meter. I would say that the majority of the issues that I have run into in the past four years were fixed by doing a factory reset but unfortunatly I also lost a ton of valuable data when doing the factory reset. It would be nice to be able to do a Factory reset to start over but to also have an option to save the meter data if you’re just trying to reset Sense because of a software issue or do a full factory reset for someone that might be installing the Sense meter in a new house.
Related topics
Topic | Replies | Views | Activity | |
Factory reset pro's and con's | 4 | 1226 | November 25, 2020 | |
Data storage and user profiles | 1 | 493 | November 4, 2020 | |
[Bug]: Factory & Data Reset Issues - 10/27 | 3 | 905 | October 30, 2021 | |
Replace failed sense unit | 3 | 362 | June 22, 2023 | |
Decided to DATA reset | 25 | 1521 | October 17, 2019 |
