Anyone else having issue? Sense down, my network is not the issue.
I saw some weirdness last week at times.
I’m down now. Although the status page shows up.
Also down again as my original post was 5 days ago.
Down here just in the last hour
I was down from looks like 5:42 to 7:52 EDT but it’s back up now. System status page showed everything up but I couldn’t even log in to the monitor nor forums here. Hope I get my data back.
Down and cannot login.
“Login failed. An SSL error has occurred and a secure connection to the server cannot be made.”
Looks like there are some response time spikes this morning, but all systems are working.
July 28, system up and down.with IOS. No issues with the website.
Up and down since 6am ET. Still having issues.
Obviously the system status monitor was incorrect this morning.
Also down here
Still a bit flaky at times over the last couple of hours. Live data has been reliable but I still don’t see historical data after 6:25 and live data doesn’t “stick”. I just see the last few minutes. Also getting quite a few “Request Failed” errors on dashboard and devices view.
at 7:24am I don’t see any usage after 2am, but I do see actual “now” readings for both solar & usage.
update
7:34am and I now have the 3am bar available.
Filling in the backlog?
I’m seeing a gap in the power meter between 6:20 and 7:20AM Pacific.
Same issue here, which I’m relieved others are seeing, since the first thing I did this morning when getting the error/connection message in the app was view the status and grumble to myself when it said everything was fine. I ended up rebooting mine and shortly thereafter I started seeing the power meter again, but was/am still getting random connection errors in the app, most recently with the dashboard. I have a gap in my power meter from 7:15 a.m. to 7:42 a.m. EDT (the latter roughly coinciding with when I rebooted it).
EDIT: Just got the error on the Dashboard again at 11:55 a.m. EDT. “Network Problem - There was a problem talking to the Sense service.”
earlier this morning it was better, i could see live data. now everything has stopped.
Of course 10 seconds later the “now” data is there again.
Still no luck with power meter or solar graphs
I only see the live current readings. No history. I have an Android phone. Has Sense support been contacted?
You would have to assume they know their bread & butter is down.
Would be nice if they would post something here along
“started then and then (including timezone), we are working on it, no data has been lost”
