I installed my Sense today and love it! I knowing the Sense Status Mains values are different. Both are reading positive values but one is always 8-9% larger in value than the other. Is this typical?
This is perfectly normal. At my house, one side is typically almost double the other. It just depends upon how the house was wired. In my case, the areas I use the most happen to be on one leg and the areas I use the least happen to be on the other. My other panel feed the upstairs outlets and light through one leg and the HVAC units through the other.
great feedback, thanks!
