Here is my Sense story after ten days of use:
I installed my Sense unit myself. The install was not difficult and went without a hitch (to be fair, I am an engineer).
Here is what the system has detected so far after 10 days of use:
The first thing it detected (within 24 hours of install) was “Heat 1”, a mysterious device that used ~800 watts of electricity for exactly one minute, spaced 6 minutes apart. It would do this 30-60 times, then stop for ~24 hours. After much searching, this turned out to be the sump pump in my crawlspace (not a basement). What’s interesting is that the pump hasn’t functioned for years, but apparently it’s still been turning on occasionally. I unplugged it since this represents a potential fire hazard. Thanks Sense!
The second thing it discovered was my HVAC (no surprise there). It’s not 100% accurate though, sometimes my A/C is on and it’s still grouped in the “Other” bubble. Sometimes it thinks my A/C is my dryer.
Next it discovered Heat 2, which is my Keurig Coffee Maker and my Toaster Over. Yes, if either of those things turns on, it’s listed under this device. This isn’t surprising as both are heating elements of similar wattage on the same breaker loop.
It also discovered my clothes dryer, though sometimes it thinks the A/C is my clothes dryer.
It discovered my microwave and so far is pretty accurate at flagging this device correctly when used.
It discovered “Stove” and “Heat 3” simultaneously, which are various elements or combinations of elements on my stove top. I haven’t quite figured out how to trigger them–when I turn them on one at a time, it doesn’t flag either of these devices. I combined them both into one device I call Stove.
Finally, it discovered the light in the master bathroom. I don’t know what’s special about this light in particular. It usually correct identifies when I turn it on, but it misses when I turn it off about 40% of the time. It also falsely triggers from other devices in my home.
In summary, it found 8 devices in the first week (but none in the past 3 days). Some of these devices it triggers off of accurately, others not so much. However, it did lead me to my faulty sump pump, which had been completely wasting money for years.
I’ve worked extensively with machine learning algorithms as part of my job, so I know what a difficult problem unsupervised learning is, especially when the input data is mixed. However, I hope both the detection process and the accuracy is improved over time. Either way, it’s a solid device for measuring overall electricity use. I do wish there was a way of downloading the raw data collected by the Sense so I could analyze it myself (is there?)
), but we are working actively on a data export feature that would compress the data somewhat. I’m curious, what would you like to see out of a data export feature? What sort of data would you like to analyze on your end?
