Hi, would it be possible that on the solar configuration wizard specify the type of solar configuration one has ? … Grid Tied, Off-Grid and Hybrid.
Grid-Tied: It would let you choose if your injecting to the grid or not and being the case show the “meter graph” differently, such as subtracting the solar from the mains and giving a more accurate result on what your consuming from the grid instead of doing the math manually (mains consumption minus solar production).
Off-Grid: Doesnt make much sense, but it could be used, the main CT’s for a second array of solar panels or backup generator.
Hybrid: Would be the Standard current configuration layout in which you could see how much solar your producing.
