Hi all.
I noticed that Sense supports KASA EP25 plugs. When clicking on the link from the Sesnse app it takes you to this set https://www.amazon.com/dp/B0B14C719T/ref=twister_B0B3CQH3T9?_encoding=UTF8&psc=1 . However there is also a cheaper set in the same link.
I bought the cheaper one, but it seems like Sense does not detect them. Did I needed to buy the Apple one or the cheaper one should work also?
kevin1
January 11, 2023, 6:20pm
2
Beware of Amazon. The Cheaper Non-Apple ones are NOT EP25s. They are HS103P4s, which do NOT monitor power and are therefore NOT compatible with Sense.
This selection:
Takes you to here:
Amazon.com: Kasa Smart Plug HS103P4, Smart Home Wi-Fi Outlet Works with Alexa, Echo, Google Home & IFTTT, No Hub Required, Remote Control, 15 Amp, UL Certified, 4-Pack, White
So, I needed to buy the Apple HomeKit version, correct?
kevin1
January 11, 2023, 6:30pm
4
Yes - but more importantly, you have to buy EP25s, the Sense-supported/tested model, and not HS103Ps. The Apple HomeKit compatibility is just one difference between the two.
ps: Amazon has a habit of screwing over Sense users. It recommends the KP303 (3 outlet / no power monitoring) as a newer model of the HS300 (6 outlet / power monitoring).
And Amazon used to offer non-compatible HS100s as options for Sense-compatible HS110s.
OK, can you provide the link to EP25s, because Sense link sends you to the wrong one.
kevin1
January 11, 2023, 6:40pm
6
The Sense link you shared works and takes me to the correct link for the compatible EP25-4P (a packaged set of 4 EP25s) for $44.99.
Amazon.com: Kasa Smart Plug Mini 15A, Apple HomeKit Supported, Smart Outlet Works with Siri, Alexa & Google Home, No Hub Required, UL Certified, App Control, Scheduling, Timer, 2.4G WiFi Only, 4-Pack (EP25P4)
The problem happens when users clicks on the cheaper Non-Apple one at $29.99. That leads to here, the NON-compatible HS103-P4:
So use the top link and pay $44.99
Thank you. I see the model number on the box.
