200amp upgrade confused sense
When you go from 100 amp to 200amp the entire panel is replaced and what I would assume is when those particular circuit were put back in the new box they are on the opposite bar (aka leg). So if your jet pump was on L1… and then that circuit is now on L2… Sense will have to find it again
