Combine Detected and KASA Smartplugs
As discussed in another thread, I have a Samsung Refrigerator with DC Motor. Sense detected “Heat 1”. It is suggested these are “heating coils” coming on 3 times in rapid succession every 3 hours for defrosting.
It was recommended I put a Smartplug on the Refrigerator.
Done.
Manually deleted the “Heat1” detection.
All is working as expected.
Several days later “Heat 1” is redetected.
I look for merge button to merge the two. Appears that it’s not there. Anyway to merge a Smartplug with a Detected Device?
If not, how do I get rid of “Heat 1” for good? I certainly do not need it now and it seems it is counted twice in Detection Total and Smartplug.
Yup, there’s a special merge for smartplugs. Go to the settings gear for that smartplug and under Manage, find the “ What’s plugged into this ?”. Under that, you should be a able to add any detections that are components of the device that the smartplug.
