Good mornin
The solar company that replaced my service installed the mains CT backwards on one leg
After they came to replace the service panel (yep it was wrong ), I reinstalled the sense and added a circuit I put the CTs in correctly.
Then instarted seeing odd curves on the meter and even negative wattage. when I went in to the my home I seen one leg was reading negative. Ah that explains it
I’ve tried doing a data reset and a factory reset a few times but they just say resetting.
I’ve waited up to a half hour.
I’d like to get the ct all facing the same direction and do a reset so it wont read negative numbers
