Hi just had a panel upgrade and service upgrade. So it looks like i may have reversed the orientation of the clamps as now both phases show negative watts.
I’d rather not have to open up the panel, will a reset fix this?
Do you have solar? And is you meter inside the meter?
Please be aware that a panel upgrade will likely cause any native detections you previously had to no longer work. Unless everything was put back on it’s original leg & even then slight changes can make signatures appear different to Sense.
Sense support can fix the wattage issue, but unfortunately you may be better off starting over.
Thanks, I’ll raise a ticket, i’d rather not lose my historic usage so thats why I was looking for a solution that did not involve a reset.
No solar, the monitor is outside of the panel.
Like i said i believe the issue is the clamps are reversed after reinstalling.
