Got it. There’s a difference between reseting the Sense itself (which Sense has to do) and re-calibrating the sensors.
If that’s correct, I’m assuming the device must be reset for it to be re-calibrated?
Only if there’s something screwed up with your device. At this point, I’d assume your device is OK and recalibration should work, unless sense tells you otherwise (which they may do if they’re looking over the data from your install now).
ok, it’s all set now. Thanks for your support
